How to Rip 3D Blu-ray in Easy Steps?
02/23/2024
Sometimes you may need to rip 3D Blu-ray to 3D MKV to play back on a certain 3D player, but how to rip 3D Blu-ray to 3D MKV video? Here in this article you can see how to rip and convert Blu-ray to 3D MKV with DVDFab Blu-ray Ripper. DVDFab Blu-ray Ripper is a powerful 3D Blu-ray converter that can convert protected 3D Blu-ray to 3D MKV within several steps and at fast speed. It also contains some advanced features for you to customize your settings and edit the video. Now let’s have a look at the process of converting 3D Blu-ray to 3D MKV.
Step 1: Load the source
Step 2: Choose a 3D MKV profile
Navigate to the profile library on the top left corner of the main interface, choose Format > Video > Filter, check the 3D option and choose a 3D MKV format. There several MKV profiles, just choose the one you want.
Step 3: Customize your video
After the source is loaded in, the longest title, namely the main movie, will be selected by default. But here you can choose other titles. You also can choose the chapters, audio tracks, subtitles, and define the names of the chosen titles. Click the “Advanced Settings” icon, you can set the parameters of video/audio and choose the 3D type. Click the “Editor” icon, you can edit the video with the built-in editor.
Navigate to the bottom of the main interface and click the "folder" icon to select a directory to save the output video.
Click the “Start” button to start the process of ripping Blu-ray 3D to 3D MKV video.
Do you also want to convert videos in other formats to MKV format? Click MKV Video Converter to learn the detailed converting process.
